Sold BLOWN Power Acoustik 980
Full Mosfet Power Supply
PWM Circuitry
Full Selectable Crossover Hi/Full/Low
Remote Dash Mount Bass Knob Control
Three Way Protection Circuit
2 Ohm Stable Stereo
Tri-Mode Capable
Variable Low Pass 40Hz-250Hz
Variable Hi Pass 40Hz-250Hz
Variable 18 dB Bass Boost @ 40Hz
Variable Subsonic Filter 60Hz- 200Hzt
Frequency Response: 10Hz to 30KHz
S/N Ratio: 98 dB
THD: 0.02%
System Distress Indicator
4 Guage Power/Ground Connection
Diamond Cut Heat Sink
Platinum Plated RCA Connectors
Line Output
High/Low Level Inputs with Floating Ground
2 Channel
4 Ohm RMS: 220W x 2
2 Ohm RMS: 280W X 2
Mono RMS: 560W
Bridged Max: 980W
Dimension (WxHxD) 13" x 2.25" x 11"
the amp would turn on and go staight into protection mode, but i took it to my local electronic store and they removed the circuit that was blown and checked everthing else so it just needs that circuit soldierd in place (im not sure what size or even what type of circuit it is) if i had the circuit i could fix it myself because it justt needs put in, the suface on the board has alreaddy been prep'd for the circuit
any kind of offers i have recently put a new circuit back in this thing and it still just goes into protection so theres somethin else wrong but i cant find it so it has to be minor!! its just sendin it into protect mode
ill let it go cheap!!!
lwrddenali
SENIOR MEMBER
lwrddenali
BFE
lwrddenali
