i just received a used lanzar opti1400d. i removed the negative on my battery and made sure i disconnected the inline fuse to the amp. after hooking everything up correctly, reatatching the negative to the battery, and reconnecting the inline fuse, the amp is not working. i AM getting power to the amp(using a DMM) from the battery, as well as the remote turn on. my rcas are correctly installed. *NOTE 10 minutes before attempting to hook this up my other amp worked perfectly fine.
my question is, how do i go about finding out if there is current flowing through the amp? im assuming i stick the DMM to the backside of the amp fuses correct?
