inferno1985
so bought new subs and a new amp. hifonics 3000d amp was pushing these 2000 watt subs pretty good . they are wired down to 1 ohm and my amp is a 1 ohm stable. over the last 2 days of my amps life it seemed like my bass was kinda dwindling down and not hitting as hard. i get in my car and turn my hu on subs and music start playing but was only loud to the point that i could talk normal and you would still be able to hesar me fine. then subs shut off so i turned off hu turned back on and nothing.. open the trunk check the fuse. not blown checked the battery connection and all connections and everything is fine. so i head to the local car audio store grabbed a pair of their volt testers. check the marine batt post. got power. chec the fuse got power check the power terminal to the amp got power. i went to check it again and accidentally hit the ground terminal. and i got power... seemed kinda weird to me since the amp was NOT on.. power and protect leds were not lit up. put the connector tip onto the remote terminsal of amp. and bam power is coming out of that also and power is coming out of the speaker terminals from the amp also. all this power is coming out of the amp and wevery terminal possible. rcas also. fuse not blown and amp isnt even on.. how could that happen? im running 2 ab xfl dual 4 ohm subs. 2 possible things i can think of is the car audio guy wired these subs down lower than 1 ohm if thats even possible and blew my amp or maybe the amp was just a faulty amp. anyone ever have this issue?? or anyone tell me why this could have happened?
