Blew something in the distro block...
Zxcvtypo
So i have http://cgi.ebay.com/Stinger-Pro-Digital-MAXI-Fused-Distribution-RED-SPD4MAX_W0QQitemZ5845165820QQcategoryZ50550QQrdZ1QQcmdZViewItem
that distro block, with the voltage readout and everything and it has a little ground wire on it. Today i was rewiring everything, and I use a socket wrench to screw in my screw for the grounds. The amps were all wired to the distro block, everything else was hooked up, all i needed to do was screw in the ground screw and i was good to go...while i was screwing it in, the end of the wrench hit the metal on the distro block and there was a huuuge pop, all the fuses blew, it started smoking..it was pretty ugly, the display doesn't work at all anymore.
I don't really care about the display not working, but i guess what i'm asking is is the wire still fused? or is the only thing that got messed up the readout. I have 1/0 splitting off into 2 runs of 4 ga
I would say if the fuses blew, then it is no longer "fused". Put new fuses in and it will be Fused once again.
Either I don't understand your question , or I just answered it. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Zxcvtypo
Zxcvtypo
Frederick, MD
Rattlebrain
