Was the sub brand new? AQ does have a strict break in,and if it was new then maybe that was the case...not letting the spiders and all loosen up. If not then what's been said, clipping, I've seen those subs take 1500 rms, well at least 1000 rms and not break a sweat.
Because after some magical breaking in ritual a 2.5" coil can dissipate 1500W of heat.....Was the sub brand new? AQ does have a strict break in,and if it was new then maybe that was the case...not letting the spiders and all loosen up. If not then what's been said, clipping, I've seen those subs take 1500 rms, well at least 1000 rms and not break a sweat.
A 1000watt amp does NOT mean the sub is getting 1000watts. I've run a bunch of SDC setups, usually a 1500watt amp for a pair. Can play them all day long since with box rise they're not seeing a bunch of power.About an hour car ride full tilt on a Rockford p1000.1 and it was only a little warm. And he plays it like that on his drives every day and it's still going after 3 months and coil is still looking new. Maybe u didnt get a good one? Idk man.And I've seen it done, not saying they can all do that but it's all install and care and know how. No need for the sarcasm hispls.
But breaking them in is a must because they usually do fail early otherwise. I'm not an expert but that's just what I know and have seen and heard.
I know that with box rise it makes it less. But box rise was minimal, set at 1 and rise was to about 1.6-1.7, 14.7 starting volts, 14.4 ending, so it was good voltage and it put out close to 1000. He now has it on the mrp-m2000 at 4 and it's still playing great. But yes, voltage drop will make the signal dirty op, and ap are known for it.A 1000watt amp does NOT mean the sub is getting 1000watts. I've run a bunch of SDC setups, usually a 1500watt amp for a pair. Can play them all day long since with box rise they're not seeing a bunch of power.
OP you clipped the sub to death Cut it apart and I'm betting the voicecoil is black and probably unwound. AP amps can easily make dirty power and as pointed out a few times, setting gain about 1/2 way doesn't mean it was a clean signal.
Very curious, for future reference. Whats the best youcan do with a 2.5 15 power wise, and whats a ballpark figure on pricing? Just incase something would ever happen to mine //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.giftoo much power for the sub. i can rebuild it for you with a beefier coil //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
