blazer 4 18s question
so how long can my box be from back of the seat to the end of the box around 30" rite? will subs up port back be better than subs and ports back?
Yes, subs up port back is the best way to make the box. Or subs up port to the side.
1st off according to your sig you have (2) PA 3000's amps and you also plan to add (2) large Kinetic 2400s. That takes up alot of room right there. You will have to make a amp/battery rack on the passenger side of the box with amps slightly angled stacked on to top of each other and the batteries under the amps.
If the box is 30" long that's putting it about 2" away from hitting the rear hatch, well for me anyways it is.
If you make the box 30" long you will have to make the box with subs up and port firing to the side.
You should try to find the exact measurements of the cargo area for a 4dr blazer. That way I can compare it to my 2dr blazer.
What year 4dr is it? I have a '92 4dr, and I only have about 28" from the back of the seat to the hatch, 38" between the wheel wells & 13" up to the window line from the floor. Subs up and port back have worked the best for me.
im going to look at the truck today its a 98 ill get measurements if i can
im going to put a 2400 under the hood and one in the back ill figure out where to put the amps when the box is done
If you do it that way your going to end up folding the seats down because thats going to be the only way your gonna have room for your amps.
i gave my measurements already for my 96.
as far as a 2400 under the hood you will have to make room for it, do some cutting and what not... it will fit...very snugly...
but it will fit... why not a 1800 up front and a 2400 in the back... that would work fine...
ill figure everything out when i go pick up the truck wich will be very soon and take some measurements then i have to find a box design i like
btlking
Registered User
btlking
Uranus
btlking
Mike Mccabe
