yeah i see your point. it is something that should be taken into consideration. when i tested box volumes for this particle speaker. changing the volume from 1.25 to 1.2 will not even yield .1 on the meter. and the tuning changing is also not important in this situation. for the type of box i am working with i need to dramatically lower my tuning from 44 to like 36 to see a .1 drop.The only thing I am wondering about resin is if the displacement of the airspace after applying the resin is going to make more difference than the resin on the walls itself.
if you end up layering the walls with resin (instead of the mdf soaking it up) you should try and displace some airspace in the non-resin box with a solid object like a piece of mdf.
That must be nice. A few inches on my port can change my score by a db!for the type of box i am working with i need to dramatically lower my tuning from 44 to like 36 to see a .1 drop.
