Birch vs. MDF test (spl results inside)
I'm not surprised by this test... in theory, people like to use MDF because it should be quieter... but in reality, it's not audible.
I'd like to see a test of a box braced vs. unbraced, and/or different thicknesses of wood.
As long as the box does not balloon while playing, you won't loose SPL. Braces or dowels are a good idea.
you should try single baffle with dowel bracing VS double baffle with no bracing (ie, is it a better idea to double baffle, or just use a single baffle with dowel braces. i have heard people claim single baffle with dowels is more effective than just using a straight double baffle.)
thats, if you didnt brace in the last test lol
well my box is going to be so small there will be no room for bracing. but some physics says this. if you have a side L with thickness R it will flex less if you half the distance of L, so .5L and R, versus if you double R, so L and 2R. meaning it is better to brace with a threaded rod than to double layer the wood. how much stronger the rod will be than double layering will change with every box, but on paper it is very significant.
resin made the impendance rise when I did my tests. Birch was louder in my tests as well but I was using more power than what the OP was using
egg
well if it makes the independence rise then it should be quieter. when i do this test i will clamp the amps. as box's get larger and larger i could see how birch will be louder.
i am going to start resining a box today so maybe friday i will get it on the meter.
What were the results from the 45 degree corners?
its kinda box to box. sometimes they will help sometimes they wont. the port has my air flow and the box has more air pressure. so in ports, i would always recommend putting corners in or even doing this:
but it takes some math to get the correct distances for the corner pieces so the width of the port never changes.
is there anyway to test the SQ of these two materials?
percussion companies are very picky with wood. their stance is some resinate more than others. the most used are hickory, birch, and maple.
sq is still by ear. i guess i could test the freq responce of each would. but i only trying to get my car loud
PSturmer
PSturmer
Minnesota
528hz
Mike Mccabe
