Birch vs 3/4 MDF SPL box
xSPLoder
o_0
I've heard both good and bad things for each. Any professional suggestions or recommendations? I already have the wood for each in my garage so I want to keep it between those 2. The box will be used for music and burbing
---------- Post added at 09:50 AM ---------- Previous post was at 09:50 AM ----------
I've been told that birch is stronger, lighter and reduces box rise
I always stick with mdf... if you need more strength add bracing and glass resin. and really I would not advise using a burp box for music... unless you plan on changing the ports which I have seen many times.
mdf is used to make boxes for a reason. birch is a good second option though. its stronger lighter but resonates at a higher freq.
im working within the 42-49HZ range.
---------- Post added at 09:53 AM ---------- Previous post was at 09:53 AM ----------
FYI, it's also going to be slot ported, no aero's
then how are you going to use it for music as well?? removeable slot ports are a lot of work. and I highly doubt that the enclosure will be big enough for a daily setup because I hope you will be making it small enough to up the mechanical power handling of the sub and to keep box rise down.
there is such a thing as a burp box that is only a burp box, not everyone needs to play music...
---------- Post added at 10:04 AM ---------- Previous post was at 10:03 AM ----------
not to mention that I am going to double layer the box
you will be much happier with birch, its massively easier to work with and will be much lighter when finished.
Awesome, thanks for the advice. I think birch is prolly the all around smarter option.
xSPLoder
o_0
xSPLoder
The Roc, NY
disturbed471985
