Bigrick31's 04 Sliverado Project Log
So got another show coming up at the end of the year. its in blythe ca. my goal for this show is to make my truck lay frame plus a few other upgrades.
curtsy of http://www.gravity-werx.com i have 3 check valves 2 for the front set of valve so if i blow a line my bags will stay aired up and one for a replacement edc. Engine driven compressor) also 2 1/2 steel braided lines 3.5ft long with swivel ends for easy connections! only $72 with shipping! these will go from my front valves to my bags.
for $250 i got this Griffin Aluminum Radiator dual core w/ Flex A Lite Dual 12" Fans. this will free up tons of room in my engine compartment and look pretty snazzy as well.
then today after i got home from work i began dissecting my dash so i can tub the firewall for my gigantor wheels! thats about as far as i got before it started getting dark. tomorrow ill have pretty much everything out of the truck and the dash will go under some super top secret fiberglass work! Muahahahahaha!!!!
This thing finished yet?
Did you do ANY research before hacking into the truck? Gas tank, wheels, spindles, and all the relocating stuff under the hood I knew about before mine was done. But, this wasnt my 1st.
My 1st took me 6 days. From NO knowledge, to laid out. I had no friends to help either. Sad thing is it's STILL going strong, over 7 years. If it was a chevy, it wouldnt have taken me 6 days, especially with it being 90% bolt on.
What wheels did you finally go with? And have you upgraded those T-377s?
Pics?
removed the old fan. wont be needing it with the new electric ones i got.
took apart the fuse box and disconnected the battery so i could remove the driver side fender.
driver side fender removed
Bigrick31
Carpe Diem
Bigrick31
Mid*Cal
MikeyB
