Bigger amp, with gain control?
are you asking about using 2 different amps? 1 for each sub? because if so. either one of those will run them just fine.. and i wouldnt suggest using 2 different amps period unless they are exactly the same amps.
I think those are the ratings for one amp.
Either way, gain is not a volume knob.
agreed.
use it at either ohm rating higher the ohm less resistance.
if you use a knob make sure your not tuning your amp and then using the knob to make it louder . youll cook them subs or harm your amp. those knobs are meant to be used as a control to get to your amp settings that work without sending clipped signals or causing distortions or power drops
1. Yes, all, I am aware that gain is not volume control.
2. Those ratings are for 1 amp and its not mono, its 2 channel.
3. I got good news....I did some digging and the amp will put out 375w @ 2ohm and 750 @ 1 ohm per channel......Bridged it will do: 1500w @ 2ohm
Its a cheater amp, so its like 25w x 2 @ 4ohm
So the amp will only be pushing my subs 75 w extra (at theoretical max draw). So I will dial the amp back slighty and the subs should perfect.
matrx10503
matrx10503
NAT, La
matrx10503
