Big problem, help?
00Chevyscott
4ch amp is going into protect mode only with peak voltage.
Key turned to ACC (truck off) >>>>> Everything works (Highs, Lows)
Key turned to Run (truck off) >>>>> Everything works (Highs, Lows)
Key turned to Start/Run (truck on) >>>>> Lows only (subs are hitting)
Key turned to Start/Run (truck on) + Stress on electrical system (power windows, air conditioner, lights) >>>>> Everything works untill voltage recovers to normal 14v +/- range
It all started after changing from my blaupunkt amp to my infinity 4 ch. I would change the amps back, but my POS monster RCA's are too **** tight and rip the RCA terminals out. I shortened my speaker wire coming from the amp (they were about 6 ft too long each before i cut them).
My wiring set up.
Battery > 4 gauge streetwires power wire > Monster One 4 gauge to four 8 gauge dist block V
8 gauge monster power wire to Inf sub amp, 4 gauge ground to chasis
8 gauge monster power wire to 4ch, 8 gauge ground to chasis
Pioneer DEH7700-MP
Infinity 1600A Mono
Infinity 475A 4 ch
Two Polk Momo 10" Subs
Infinity Kappa 6.5" components up front
Polk 6.5" coaxials in back
Monster 4ch RCA's (shitty, i hate them)
Streetwires sub RCA's
Have you actually metered your voltage when it is cut off??? Some amps have a really retarded operating voltage and can't take high 14's to 15 volts. I don't know exactly what your electrical system is though.
bump. it seems the cutoff voltage is around 12.2v
come on guys, i need to get this fixed //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
00Chevyscott
00Chevyscott
Arlington, TX
00Chevyscott
