big noob here..
Alpine type X speakers and amp, JL speakers and amp. If it were me I would get comps for the front and coaxial for the rear running off head unit power. Maybe some MB Quarts with a MB amp.
Honestly, I'd skip the rear speakers. You barely even hear rear speakers when they are on, they add a bit of fill, but that's it. With a 1000 fronstage, you could get some kickass components. 1 set would be just about as loud as 2 lower end sets, but would sound ALOT better, they may even be able to get louder, since you could use a bigger amp. If you like alpine, I'd get a set of type X's and an alpine pdx2.150. Lots of power for an amazing set of speakers, I really believe
your money would be much better served that way. A w6 is a really nice sounding sub, no reason to ruin your overall sound using cheap components. That would probably be a bit under 1000, if so, you can always deaden your doors, that'll really help give you the midbass required to keep up with the w6, and make your car a bit quieter in the process. All and all, I really do feel this is the best way to spend your money, you don't have to listen to me, but it's a good idea;)
I just swapped my S600 Hex set for a set of Rainbow CMX 265. Without any real tuning, yet I have to say they sound much better. I am giving them 125 rms per side. I am pretty unhappy with the Diamonds, I have had them in less than a year and one of the woofers is already rattling. The midbass was lacking and compared to the new Rainbows they were not very detailed. I was much happier with the M6 set I had before them. I would try and listen to many different brands if you can and see what sounds good to you.
This Rainbow set I got is the CMX 265 here:
http://car.rainbow-audio.de/products/introduction.php?lan=2&pro=1&lin=6
If you consider the Rainbows PM 6spdcoupe for some more details about Rainbow.
Good Luck!
ok, my Head Unit puts out 45x4 watts, if I get coax speakers for the rear doors, what kind should i get?? i honestly dont know what coax's are lol..
im looking into comps for the front and one amp and ill get some coaxs thanks to you guys..
ok i found some comps for: $359.00
http://www.premier-audio.com/ProductDetails.asp?ProductCode=Rainbow%20CMX%20265&click=35
rainbow amplifier for: $449.00
http://www.premier-audio.com/Rainbow-Kraftwerk-KW4150-1000W-4-Channel-Amplifier-p/rainbow%20kraftwerk%201000w%204-chan.htm
some rainbow coax 6.5": $120
http://www.premier-audio.com/Rainbow-KX-165-6-5-Coaxial-p/rainbow%20rainbow%20kx%20165.htm
my alpine Head Unit doesnt put out much power, will it be pointless to get these coaxs?? i just checked and my unit puts out 50x4
ok i found some comps for: $359.00http://www.premier-audio.com/ProductDetails.asp?ProductCode=Rainbow%20CMX%20265&click=35
If your going to be looking at anything in the Rainbow line do yourself a favor now and pm 6spdcoupe...besides your in Queens so that makes you somewhat local.
I had the Diamond s600, I hated them. Had a Zapco 360.4 pushing them, sounded terrible. I got the Boston Acoustics Pro60's, sound hella better. If you got a G to do you fronts, I'd go with the Boston Z6's and an amp that pushes 150rms. IMO.
question: do you recommend that i get two component set-ups and get a 4 channel amp to power only the 6.5"'s and leave the Head Unit to power the tweeters??
i went to my radio shop:
rear- 6.5" JL coaxes
front doors- 5.5" JL comp set
front kick panels- 6.5" JL comp set
AMPlifier- 400/4 JL
total $1,800 for parts and labor.
what do ya'll think??
joeygreyhawk
joeygreyhawk
queens
NJAV1
