big fat stuff
Originally posted by burton56911:2 questions
Can you hook more than 1 amp up to a sub??
Depending on the sub yes you can.
Can you bridge the front right channel and rear right channel on an amp or do they both have to be either front or back in order to bridge?
Also dependant on the amp. But most amps can only have the front channels or the rear channels bridged.
It may be possible if you run both amps in series with the sub i.e. (pos.+ of first amp to pos.+ of sub./ neg.- of first amp to pos.+ of second amp/ neg.- of second amp to neg.- sub.) Seems to me like it might work, however I have never heard of anyone trying to do it. If the other guy that responded saw mutiple amps to a coil, like he said 4 amps to two coils, then that is the only way I can see it possible. Keep checking to see if my theory works, or try yourself at your own risk.
burton56911
burton56911
United States
burton56911
NorthFramingham
    Jun 30, 2026
