Big Battery at Advance
//content.invisioncic.com/y282845/emoticons/cuddle.gif.bd1b29c179c0482f8313dbd790b74c94.gif
thanks man. hey infamous i was really just kiddin with ya, hope you dont think i was bein a d ick. i was just playin around
where are the rest of the specs besides 134ah
C&D Technologies Dynasty High Rate Series UPS12-475FR
Valve Regulated Lead Acid Battery
12V 134AH @ 20 Hr. Rate
12V 475WPC @ 15 min. rate, 1.67vpc
Features
10 year design life @ 25 degree C
2 year replacement Warranty
Absorbent Glass Mat Technology, AGM
Flame Retardent Polypropylene case
No restrictions for Ground/Air Transport, non spillable battery
Specifications
Dimensions = 13.57"L x 6.76"W x 10.93"H
Weight = 100lbs
I was at advance auto parts a lil while ago, looking at a big battery they had there called a truck and farm battery. I remember someone on here making a reference about them recently, but i can't find any info on them, other than its a group 31 with 195 ah on it iirc. anybody have any info on them? are they sealed?
195 is probably the reserve capacity. It is similar to Ah but calculated differently so are higher numbers.
fwiw out of those two batts I would pick the optima. But either way make sure you get it load tested as soon as you buy a used batt because resting voltage means nothing!
fwiw out of those two batts I would pick the C&D. But either way make sure you get it load tested as soon as you buy a used batt because resting voltage means nothing!
great call
yea but these are longer lasting. and have more ccas i believe. and yes 2 would be about as good as one but thats more wire, connectors, SPACE, ect...
mine have 900 cca each 1125 ca //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Voltage: 12v
Minimum Weight: 59.8 lbs.
Cold Cranking Amps: 32°F 1125, 0°F 900
Length X Width X Height: 12.81" X 6.50" X 9.31"
Capacity Ampere Hours @ 20 Hr Rate: 75
Reserve Capacity: 155
Internal Resistance (ohms): .0025
//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
and for the price i sold the other 2 come onnnnnn
SavageBlackout
Team DC
SavageBlackout
Watson, LA
infamous_e46
