Sold another batch so heres more... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Alright so I get these batterys locally and they are bad ***... Me and my buddys been using them for a while and love them so I thought i'd sell a few... I also get a bit of a deal and figured I'd pass that on as well. I can get a few of each, the big ones are the size of kinetik 3800, 134ah... Then the small ones are the size of like a hc1800... They are all AGM non-spillable batteries of course and are TANKS... Sacramento CA Area Pick Up Or Ship... Pm me for multiple deals of course. Also will take Offers and some Trades... So let me know...
Looks like about 10 of each on the pallets And then another pallet of the small C&D 75ah ones
Also like I said in other thread there will be 90Day Exchange warranty for anyone local but even if its past 90 days and you have a problem, let me know and i'll see what I can do.
Oh and also Refs.. I forgot but umm got a few on ca.com and then tons local... zfrerichs just picked some up, umm me, 99vic, and loganberry been running some for a few... Ummm know quite a few guys here personally and done deals such as alarms, boxs, iunno but ForEvrBumpn, B Slaps Yo Mama, civicman, colt 45, Noobtastic, zfrerichs, ect.. Team Nor*Cal Bass - 99vic, Loganberry, Ipod, thehoe92 Also got 200 or so 100% feedback on ebay and 99vic already said he'd put his superseller 100% feedback on the line for me as he will be the one getting a little discount on shipping the batts for me.. (THIS IS COPIED FROM SMD SO YOU CAN READ OR IGNORE) Zferichs is also on here tho, donno who else
Prices And Also Open to Trades
C&D UPS12-475FR (134AH) - 180 + Ship
C&D UPS12-270FR (75AH) - 100 + Ship
GNB Splinter (75AH) - 110 + Ship
NPX-150R (40AH) - 65 + Ship
C&D Technologies Dynasty High Rate Series UPS12-475FR
Valve Regulated Lead Acid Battery
12V 134AH @ 20 Hr. Rate
12V 475WPC @ 15 min. rate, 1.67vpc
Features
10 year design life @ 25 degree C
2 year replacement Warranty
Absorbent Glass Mat Technology, AGM
Flame Retardent Polypropylene case
No restrictions for Ground/Air Transport, non spillable battery
Specifications
Dimensions = 13.57"L x 6.76"W x 10.93"H
Weight = 100lbs
C&D Technologies Dynasty High Rate Series UPS12-270FR
for UPS standby power applications
12V 75 AH @ 20 hr rate,
12V 282 watts/cell @ 15 min. rate
57lbs
Dimensions = 10.27"L x 6.82"W x 8.82"H
FEATURES
Flame-arresting one-way pressure-relief vent for safety and long life.
Thermally welded case-to-cover bond to eliminate leakage.
Absorbent Glass Mat (AGM) technology for efficient gas recombination of up to 99% and freedom from electrolyte maintenance.
Computer-generated grid design optimized for high power density.
UL-recognized component.
Multicell design for economy of installation and maintenance.
Can be mounted in any orientation.
Not restricted for air transport – Complies with IATA/ICAO Special Provision A67.
Not restricted for surface transport – Classified as non-hazardous material as related to DOT-CFR Title 49 parts 171-189.
Computer designed lead, low calcium alloy grid for minimal gassing and ease of recycling.
Case and cover available in both standard and flame retardant polypropylene.
Flame retardant polypropylene case and cover compliant with UL 1778 (optional)
GNB Sprinter S12V285F
12V 285WPC @ 15 min. rate, 1.67vpc
Features
8 year design life @ 25 degree C
3 year replacement Warranty
Specifications
Dimensions = 10.25"L x 6.85"W x 8.8"H
1300 ca
1130 cca
75 ah
63 lbs
NPX-150R
Enersys formally Yuasa NPX-150R battery are designed using proven gas recombination technology which removes the need for regular water addition by controlling the evolution of hydrogen and oxygen during charging. Gas recombination provides the user with freedom to use lead acid batteries in a wide range of applications.
Features & Benefits
• Design Life: 3-5 years @ 25ºC(77ºF)
• UL recognized
• Approved for shipping as non-hazardous, non-spillable
• Operates in any position
Applications
• Emergency Lighting
• General Electronics
• Medical
• Mobility
• Security
• Uninterruptible Power Supply
Technical Features and Benefits
Construction:
• The construction and sealing techniques of the Genesis NP battery guarantee leakproof operation in any position with no adverse effect to capacity or service life.
Electrolyte Suspension System:
• All Genesis NP batteries utilize an electrolyte suspension system consisting of a high porosity, glass fiber material which in conjunction with plates, totally absorb and contain the electrolyte. No silica gels or any other contaminants are used.
Gas Generation:
• Genesis NP batteries incorporate a built-in design that controls gas generation and induces recombination of more than 99% of gases generated during float usage.
Maintenance Free Operation:
• There is no need to check specific gravity of the electrolyte or add water to Genesis NP batteries during float service life. In fact, there is no provision for this type of maintenance.
Low Pressure Valve Regulated System:
• All Genesis NP batteries are equipped with safety release valves, designed to operate between 2 and 5 psi and automatically reseal. Hence, there is never an excessive accumulation of gas within the battery.
Heavy Duty Grids:
• Heavy duty lead calcium tin alloy grids provide an extra margin of performance and service life in either float or cyclic applications, even after repeated over discharges.
Cyclic Service Life:
• More than 1000 discharge/recharge cycles can be realized from Genesis NP batteries, dependent on the average depth of discharge.
Float Service Life:
• Genesis NP Series batteries have an expected life span of 3 to 5 years in float service applications.
Self Discharge - Shelf Life:
• The self discharge rate of the Genesis NP series at room temperature is approximately 3% of rated capacity per month.
Operating Temperature:
• Genesis NP Batteries may be operated over a broad range of ambient temperatures.
Deep Discharge Recovery:
• Genesis NP batteries recover their capacities even after repeated deep discharges.
Specifications
Chemistry Lead Acid
Voltage 12
Capacity 40,000 mAh / 40 Ah
Rating 480 Whr
Length 7.76 inch / 19.71 cm
Width 6.50 inch / 16.51 cm
Height 6.89 inch / 17.50 cm
Color Gray
Weight 34.2 lb / 15,512.78 g
Features
Specifications
Weight = 100lbs
57lbs
FEATURES
Features
Specifications
1300 ca
1130 cca
75 ah
63 lbs
NPX-150R
Features & Benefits
• UL recognized
Applications
• Medical
• Mobility
• Security
Construction:
Gas Generation:
Heavy Duty Grids:
Float Service Life:
Specifications
Chemistry Lead Acid
Voltage 12
Rating 480 Whr
Color Gray
