ccab
For The Horde!
at 5:26 on the big 3 video.
there is a wire there and the guy says now that the engine block ground is complete and secure now its time to install the battery..where did that wire come from? because i didnt see the guy put that wire in or explain anything about it during the video? is that only for if your replacing your stock car battery or what? i need some help on this because im doing it soon.
Please dont post any forums or anything on how to do the big 3. i just need to know where that came from..or whats up with that.
here is also what i have written down for the big 3 and make any adjustments if needed:
1. Alternator(+) to (+) Terminal on battery
2. Engine Block Ground(-) to (-) on battery(He didnt explain this!!)
3. Battery(-) to Chassis
Notes: remove factory connection(Alternator), attach 0 gauge wire to alternator(-), secure wire away from engine and radiator, attach wire from alternator to fuse block with out fuse in there. and then i drew a little diagram that basically says alternator(-)wire goes to one end on fuse block then you use a little bit more wire and connect that little bit to the other end of the fuse block and connect that to the (+) side of the battery. **the alternator charge wire should be fused within 12" of (+) battery terminal. Next: grounding to strut tower for the main batter. sand it down to bare metal. Prepare 0 guage ground wire with terminal and sand the terminal. make the connection.(attach the wire to ground and tighten it.
What am I missing?
What am I missing?
