nyg052003
Looking all around my car, 95 Mustang GT, the easiest spot that I found after looking all over and under real good is the power steering bracket. There are 2-3 bolts that secure it to the engine and there are 2 that I can get to. One I know for sure looks like it goes into the head and the other may or may not go into the head or might go directly into the engine. I wanting to use the 2nd bolt which may go into the head or may not but I'm thinking even if it's still an engine ground....
thoughts...................................
on edit, there is a spot on the other side where there is a ground that appears to be connected to a motor mount. Might be a firewall to engine ground I guess.
I will do a run from Neg batt terminal to chasis also which will be a very short run as there is a spot right close to the neg battery terminal
