Big 3 - someone needs to redo the sticky on it. Pics are gone now
I want to learn how to do it, it would be more helpful with pics ;D
It's a breeze man. I had no knowledge of any of this, but you just follow the wires from the battery... Bat(-) to ground. Get some 1/0 with ring terms on each end and add it on top of the current wire. Follow positive wiring from the bat, to your alternator and do the same. Then find your engine block and find the grounding wire for that and do the same. Just make sure you have the grounding wire removed from your battery so there is no risk of electrical shock.
Bassin Brandon
Bay Area, CA
Buck
