Big 3 in 3/0 pointless?
we did a Kinetik 2400 (was a ***** making it fit under the hood) 300A alt install in my brothers '06 trail blazer pushing 2k rms subs & 800 rms front stage......& wired the big 3 w/ 2/0 weld wire (left all factory wiring, easy to return to stock when hes ready to sell)
battery + -- alternator
battery + -- fuse box
battery + -- starter
battery - -- alternator casing
battery - -- frame
battery - -- fender
battery - -- firewall
then 2/0 runs for the amp + & - back to the batterys. Some say it's overkill, but we had plenty of 2/0 weld wire, 2/0 weld lugs, & a hydraulic crimper....so..whatever.
when you're using 1/0 2/0 etc gauge wire make sure you use the proper tools to crimp them, a vise or punch won't work well. wrap the ends in tape to protect the exposed copper. if you dont have the equipment its worth the $$$ to have a shop do it for you.
Just because your alt is rated at 300a, you won't see a consistent 300a out of it.
If you need more than 1/0, then double up. It gets hard to work with larger wire.
This. There's a reason most of the big competitors just run multiple runs of 1/0, it's cheaper and easier to work with. Once you get up in those welding cable sizes it becomes harder to find the terminals to fit and you end up paying a premium for them. If your really going to be running that much power, then just do several runs of 1/0 (both + and -) to the back.
Magnus
U mad brah?
Magnus
Midwest
bubbagumper6
