DammitJames
only true way to check if you have a good ground is to do a voltage drop test ohms will tell you this or that but it is not a good test for checking for a bad ground it could be fine but when you run power through it, it can still dropGround circuit resistance can also be checked by measuring the voltage drop across the circuit with a DVOM set on, the 2 volt scale. The voltage drop will be zero across a "good ground" circuit.
put your meter on DC volts and put one lead on your amp ground then put the other lead where the amp is grounded and turn it on and play music if it reads more then 0.2DC Volts than you have a bad ground... again your putting both leads on the ground side and measuring volts... yes it sounds funny but this is the best way to check your ground... same can be done on the power side to check connections
