no but ill take a look at it. maybe i just need to up grade my subs. fi btls??//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gifYou do the gain setting tutorial from the amp section of the forum?
31-34ish would be a startok i read the tutorial. buti dont really understand. i have my subs wired down to .67 ohms. so how many volts should i have commin from my sub channel?
i did that but i watched my power voltage to make sure i didnt drop below 12 voltsBut just turn gain all the way down and turn your volume up to where you listen to it normally and start turning gain up til it sounds distorted a bit than back it down
I would hook up a multimeter and set the gain so you get around 32 volts. Then you would be good to go.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifumm. idk like 1600-1800? ill check though.
