big 3 done but did it help?
then wats the ****in point of doing it?
i no that there is less resistance so that means more current flow. and it lets you take better advantage of your alt.
From the "Big Three Sticky" at the top of the forum
Replacing/adding larger wire to these three critical spots can reduce or rid your electrical system of dimming and voltage drops. Overall, giving your charging system a larger surface area to travel over, will stabilize power and relieve strain on the alternator and battery.
not real bad. te main reason i did the big three so that i could turn my gain up more. its at less than 1/4
I don't think that is a good reason to do the big three. The gain should be used to match the volume from the headunit. Its not a volume dial for the amp. If fact, it would be great for the amp to run that less than 1/4 gain.
spike_e
ballin on a budget
spike_e
prattville AL
ebrunn
