OP
PurpleDiesel
- Thread Starter
- #16
Thanks for this info I thought it was VERY strange that the car was running Horrible at first start up but that makes sense. I'm going to drive around a bit and see if that helps.another member up here has a newer honda pilot and it did a few little quirky this when first started back up, something about a E.L.D. switch having to learn the cars electrical system after being unhooked, double check all the connections and make sure there are no loose strands shorting anything, then try driving it around the block and see if after two engagements of the cars cooling fans if everything hasn't went back to normal.
