Big 3 and power cap?
Muzzy
I have just completed the alt to battery and batt neg to ground. I havent got around to doing the last as i cant find a place on the engine block. I still have dimming problems. My system is only 500 watt rms. Would a cap help out my alt response time? because on long base notes my lights dim and then return to full brightness. Any ideas?
I have a 2001 renault clio. Its only got a 70A alternator. I used 4 Gauge wire because i couldnt get 0 gauge at the time. And the alternator bracket is too hard to get too so need to find somewhere else?
just find a bolt on the engine somewhere. i have mine on my alt bracket and there was a bolt at the bottom of the engine as well that i grounded. i would try to get 1/0 gauge and see if that helps. also, how old is your battery? it may be time for a new one
Yes the battery is pretty old. Its low ampage aswell at only 36AH and 280 cold cranking. Would a higher ampage battery help my dimming. I havent got the money for an optima. So would i kill a normal battery with my system?
Ive done big 3 now and installed new 60 ah battery and im still getting slight dimming... anything else i can do?
its a 2001 renault clio 1.2 with 70A alt. i cant afford a new alt... this is stupid only for 500 watt rms! its just the response time of the alt coz its fine if its a long bass note. theres gta b another way?
Well I dont think you can get much bigger than the 60 AH battery since you only got a 70 amp alt. Dont understand why you would be dimming any though...unless you did the big 3 to a couple bad grounds and/or grounded the amp bad. Would make sense to me anyways...
Muzzy
Muzzy
Brum
Muzzy
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
