Best way to make rear glass from rattling?
The rear glass on my suv rattles like no other now.... What is seriously the best way to stop this shiit..... I have already deadend the trunk hatch with a few layers but the glass won't stfu
closed cell foam. that what im gonna try anyways i cant stand it rattaling in my jeep for the rear window, so for now i turned the box around so port fires in the cabin.
Take foam and put it around the entire perimeter of your window. I was getting some BAD rattling that I could hear over the sub at full tilt...weatherstripping fixed that right up.
" Best way to KEEP rear glass from rattling? " facepalm....
The best way to prevent your rear hatch glass from rattling would be to do like every said, add foam or weather stripping, however, if it is rattling from inside, then you need to use a stiffer weather strip guide around the with that comes stock OEM. And check the mechanism in the door and try to make sturdier
I will be painting the back window with black paint from inside to blacken it out,then getting a sheet of 4x8 1/2in thick foam from Home Depot,and a sheet of Birch,or Plywood, and cover it,and completely sealing the window off, as I only need outside side mirrors min,for the Tx State DOT Regulations,and hopefully gain some DB as well..Looking to do the same with my side windows on the xcab portion also..They Vibrate open as im going down the Highway/or just driving period!!Will deff be done soon!!
My phone inserts words whether I like it or not
Imtjnotu
Me Gusta Edition
Imtjnotu
San Diego CA
Imtjnotu
