Best way to build this Fiberglass box?
preprunner
I will be building my first fiberglass box with the arrival of my 3 12w6v2's and I found a picture of this box that I really like and want to copy. I'm just wondering what the best way of doing this is (without the screen mount)...like as one big chamber and glue 3 rings and cover that? Or make each sub area it's own box then combine them?
I also wanna know what you do with the wires when you mount a sub inverted. How do you mount it and do you feed the wires back through the box?
Thanks in advance, here's a link of the box.
Box Pic
that box looks like 3 chambers. You can do either way but 3 chambers is probably better if your new. inverting the sub you will need to drill small holes into the glass to un the wires through and seal them inside with silicon.
BTW they did a really shitty job on that box. that mdf sub structure looks like *** and he should of rounded the sides to they didnt stick out like that. Also the finish work is nasty.
Excuse my ignorance, I'm reading as many tutorials and stuff as I can, but as a noob it's sometimes hard to picture.
For the "ridges" on either side of the center sub, are those MDF "side panels" under the glass, cause how else would it be there.
Thanks again.
preprunner
preprunner
Orlando, FL
preprunner
