Best route to repairing my Treo 3.1?
SiX
Well, I ended up buying 2 Treo 3.1s; one of them being blown. For all who dont know the specs, they are, 3k @ 1ohm, 2k @ 2ohm, 1k @ 4ohm. The bad amp has 6 blown fets on each side of the power input/output end of the amp. I would attempt to do the repairs myself but don't have & cant find access to the parts. I've already emailed Treo a few times and cannot get a response from them. I will post pics as soon as my batts are charged in the cam. If anyone has any ideas or knows of a reputable source for repair, lemme know.
Just be careful where you take your equipment. A local repair shop which had been here for years(at least 15) who I had used many times had moved with my two amplifiers I had dropped of with them. Didn't find out until I went down there to check on them and that's when I found out basically a 3 weeks before they moved. Well when I checked on my equipment( a month after they moved) they said they couldn't find anything and that there was no record of me dropping the stuff off. Even when I showed them the tickets they kept giving me the run around.
So just be careful
So just be careful
That sux.
I can fix it for you if you need me to.If you need references on the forum for work i can give them to you.I have everything and all parts and you just pay after i fix the amp and in most cases it takes 1 or 2 days to fix,maybe more if the amp has been fixed before.Then i have to go through everything and probe 100% of the amp.I also take broken stuff as payment doesn't matter.The payment covers parts,labor,shipping back and i cover what ever i repair only.Hope this helps or good luck where ever you go.
SiX
SiX
Flint MI
shallowfu
