Best powering option? 2 batteries? Isolator? H/O alt?
So I have a 2013 subaru wrx sedan which will be running 2600w rms at most. The stock alt is a 110A alt. I would like to hold off on getting a new alternator for now.i plan on doing the big 3 as well.
I did order a XSPower D3400 to replace my under hood battery, is that a good idea having a deep cycle up front? I was also considering running one of those small batcaps in conjunction with a Knu knf60 distribution fuse block. Should I do this or will the D3400 be enough for now? If I should add the batcap or should I get a battery isolator or just run them together? If I do use the D3400 and the smaller batcap battery in the trunk would that put too much strain on the alternator for the time being until I get a H/O?
Just wanting some opinions on what I should do for now to get this system up and running without going all out on a H/O alt just yet. Thanks.
So would adding that small back battery help or be sufficient until I upgrade my alt? Also will this strain the alt too much? Lastly should I get an isolator or just run the batteries through the distribution block?
I've use dc power and singer and I just bought two Excessive amperage alts
do you have any recommendations for alternators that are affordable for my given setup? also should I run an XSPower secondary XP series battery in the back instead of their primary battery sources?
also how should i wire it all up? just in series with a Knu KNF60 distribution block?
does anyone know if the dcpower alternator will fit a 2013 wrx? it stops at year 2010?? also do you think 2500w rms needs 2 batteries and a 250-270amp alt?
lyons238
lyons238
Coventry, RI
lyons238
