Best possible amp for 2 p212d4 12in DVC RF Punch Stage 2?
fmalucard
hi guys, im new here and i was just hoping for some advice from the experienced people here. i recently purchased 2 12in rockford fosgate punch stage 2 DVC subwoofers (p212d4) and i was wondering what amp i could buy to push these subs. i dont really want to break the bank, so probably around a $200 dollar budget, if possible. if not, any other suggestions will be fine, as ill try to save up money to buy something a bit more expensive, but id prefer to get one under 200.
as for any ideas i might currently have, ive been looking at the following amp:
http://www.crutchfield.com/S-7nKb9GXgELk/cgi-bin/ProdView.asp?g=120&I=158XM2002
it does 200 watts RMS x 2 at 4 ohms (250 watts RMS x 2 at 2 ohms).
any suggestions? thanks in advance.
I would look into something that does at least 600 wrms @ 1 ohm. These will probably fit the bill. Just make sure you get an amp that is 1 ohm stable because you have dual 4ohm speakers so wiring to one ohm will get you the most power out of the amp.
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16338
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=18150
thanks for the input, really appreciate it. im new to this whole thing but i love bass, always have. this is my first time putting something together.
i take it since the speakers are dual voice coil, i would have to bridge the amp to connect both to it, since both of those are mono?
if so, which of these should i buy? ive heard of hifonics, but the other brand not really. should i go with that one?
fmalucard
fmalucard
Eagle Pass, TX
DRMVP21
