Best enclosure for 2 10" jl audio w6v2d4
klassik
I'm Looking For Feedback On What Is Or Will Be The Best Enclosure For 2 10" W6V2D4 It's Going In The Trunk Of A 2002 VW Jetta And I Don't Want It Eating Up My Trunk Space Either Want 2 Keep It As Compact As Possible But Getting The Best SOUND QUALITY Out Of It
I prefer ported, but there is a good size difference in them both. If you do a single slot port you will add a good amount of space versus areo port(s). What type of must do you like?
In most cases the type of enclosure will fall on a few options you have.
1. Overall space you are willing to give up for the enclosure
2. Type of music and preference of loudness
3. Amount of power you would like to use
4. If you have a preference on the aesthetics of one or the other.
Well I'm Trying 2 Conserve As Much As Possible But Wanting The Best Sound Outta My W6s.....
Well It's Mostly Spanish, Reggaeton, Reggae, Old School Hip Hop, House/Techno, Alternative Rock, And Sum Rock N Roll...As far As
Loudness I Want Best And Most Even Though I Won't Be Listening To It Like That But Would Like 2 Be Able 2 Show It Off From Time 2 Time
Well I Want 2 Generate @ Least 500 Watts Out Of Each Sub So Ur Looking @ A 1,000 Watts In Total
I Really Have No Preference As Long As My Requirements Are Fulfilled
a sealed enclosure would be a good option. You could do something fairly small. Like a 29 wide x 12 high x 10.25 deep(just a rough idea..not exact). I would use a divider though.
A ported options would be more larger but not by a huge amount. 29 wide x 15 high x 15 deep(again just a rough idea not exact). This would be a common chamber enclosure with a single port and tuned to around 33-35hz
if you want to save space then go sealed... as long as you are pushing a good amp then you should be fine. If you want to go ported then get it built to JL specs. there are a few guys on this site that have good reps for box design/build. I have a box being built right now by one of the members on this site.
klassik
klassik
Brooklyn, NY
klassik
