best amp options under $500?
gn_rx7
Amp will be used to power 3 way front stage (focal 165f3)
Need at least 75 wpc and would like something in the 100-125 wpc range.
Got a good deal on a PDX-F4, but not sure if i should go with AB class instead of D. Currently, I only need 2 channels, but 4 channel would be optimal to provide the option to bi amp the mid/tweets and 6.5" separately or provide the capacity to add an 8" mid bass later.
Have the full range D class amps caught up from an SQ perspective or are the AB class or tube amps still a lot better for mids/tweets?
Currently researching these amps and will consider any other suggestions under the $500 range.
JX360/4 or 2
Ks300.4
Helix b4
Butler TDB 275
Would also consider spending a little extra if there is an amp that is significantly better for a few extra $
Is a Mosconi worth the extra $? That is what was running the speakers on the demo board.
gn_rx7
gn_rx7
Houston
LosIsATool
