Best amp kit to buy without spending tons on money
Pick what wire company you like and buy the wire you need, not in a kit. You can normally source out the wires you require with out spending a lot on a kit that may not have exactly what you want.
Im running 4GA wiring right now on my hifonics brutus 1700 with two CVX 12' and thinking about upgrading my wiring for better quality. what should i buy?
The first thing you should buy is this:
Stinger SVMB Stinger SVMB Blue LED Voltage Display
There are cheaper, but the Stinger can be calibrated, the cheaper ones might be off by .2 or .5 volts. I would recommend this tiny investment, no matter what.
Might as well upgrade wire thickness in case you decide to upgrade. Wont cost tooo much more and youre on the border for bigger wire anyways. My $.02
What the difference between the CCA and OFC?
CCA = copper clad aluminum, mostly aluminum strands coated in copper
OFC = oxygen free copper, pure copper strands
OFC can usually handle more current with less voltage drop and, is usually more expensive.
This is correct.
CCA is 10% copper 90% aluminum
OFC is 99.96% pure copper
OFC is a much higher quality product. CCA also has more resistance than OFC.
MK5 Fahrenheit
MK5 Fahrenheit
Plymouth, MN
Spooney
