Best amp for infinity 6012i speakers?
Hi i was woundering which of these three amps would be best for my 4 infinity 6012i (MTX TA3404) (MTX TC4004) (KICKER KX350.4) im only interested in these three
Infinity 6012i Details:
2-way car speakers for 6-1/2" and 6-3/4" locations (pair)
Plus One+ poly woofer cone with high-roll rubber surround
rotating UniPivot silk dome tweeter
power range: 60 watts RMS (180 watts peak power)
frequency response: 53-21,000 Hz
sensitivity: 92 dB
Intermount III mounting system for fit in 6-3/4" openings
top-mount depth: 1-15/16
MTX TA3404 Product Description:
MTX Thunder 4-channel amplifier
RMS Power Rating:
50 watts x 4 @ 4 Ohms
100 watts x 4 @ 2 Ohms
200 watts x 2 @ 4 Ohms (Bridged)
Wired EBC Remote Subwoofer Bass Level Control Included
Fan cooling with XTC thermal regulation technology
Prizm EFX customizable lighting accents
Selectable high-/low-pass filter (85 Hz at 12 dB per octave high-pass, and 24 dB per octave low-pass)
MOSFET power supply and output stages
CEA-2006 compliant
Speaker-level inputs with Smart Engage
Preamp inputs and outputs
Dimensions: 12-11/16" L x 9-5/8" W x 2-1/2" H
MTX TC4004 4-channel car amplifier
» 50 watts RMS x 4 at 4 ohms (100 watts RMS x 4 at 2 ohms)
» 200 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
» each amp is tested and certified to produce 10% more power than listed
» variable high-pass/low-pass filters (40-350 Hz, 12 dB/octave)
» variable Thunder EQ bass boost with wired remote control (0-18 dB at 40 Hz)
» preamp-level inputs
» speaker-level inputs with Smart Engage
» N-Channel technology for efficient power output
» CEA-2006 compliant
» 4-, 3-, or 2-channel operation
» 8-gauge
» 14-1/2"W x 2-3/8"H x 9-7/8"D MTX TA3404
KICKER KX350.4 Features:
60 watts RMS x 4 at 4 ohms (90 watts RMS x 4 at 2 ohms)
175 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
variable high-pass/low-pass filters (50-200 Hz, 12 dB/octave)
variable bass boost (0-18 dB at 40 Hz) with wired remote level control
speaker- and preamp-level inputs
TIA
2spik4u
canada
2spik4u
