Ya dun that I have a brz 1700 everybody says it does rated I have it weird at .5ohm's with box rise to 1.57 at 40hz it put out 774 wrms maybe it not being high end amp it does not put out rated I just want tru 1200 or so wrmsIts in the stickie at the top of this thread dude, set ure gain via DMM. Where your gain is set only has to do with your preout voltage, the gain IS NOT A VOLUME KNOB.
THat being said, AQ1200D or a DC 1.2K .... The AQs are about 280, i love mine. Both amps are .5ohm stable on good electrical should do 1500-1700wrms
those are rated at 14.4 volts. So if your voltage was dropping pretty low, that power is probably about right where it should be. But for $500 you can get a pretty nice amp in the 1200 range.Ya dun that I have a brz 1700 everybody says it does rated I have it weird at .5ohm's with box rise to 1.57 at 40hz it put out 774 wrms maybe it not being high end amp it does not put out rated I just want tru 1200 or so wrms
I would imagine that amp wired at .5 is dropping pretty low. Your not going to get much more running a better amp at .5 if you dont fix your electrical first. You will just smoke a better amp and not the BRZthose are rated at 14.4 volts. So if your voltage was dropping pretty low, that power is probably about right where it should be. But for $500 you can get a pretty nice amp in the 1200 range.
Its going to take more then that. .5ohm daily is really hard on everything.Ya im doing the big 3 next weekend
Ok well thats good, just saying were the gain is has nothing to do with how powerful the amp is. But my AQ1200 does 1200wrms easy @ 1ohm and of course the DC does it no sweat. But .5ohm daily is hard, idk either change to 1ohm set-up or run at 2ohmsYa dun that I have a brz 1700 everybody says it does rated I have it weird at .5ohm's with box rise to 1.57 at 40hz it put out 774 wrms maybe it not being high end amp it does not put out rated I just want tru 1200 or so wrms
A H/O would help ALOT, but if no that then sum big batt(s), if i were you change to a 1ohm sub or configuration. Or look for an amp that does 1200wrms @ 2ohms. It will be much easier on your electrical. Most kickers only go down to 2ohm stable, how big is your stock alt?So i will need a alternator?
ew why, atleaste go with an lanzar opti2000D, i thought the alpine m series didnt even do ratedThink i will just get the alpine m2000.
