Best 5-Channel Amp(SQ)?
yea I was reffering to the power part.
This is my final hold up on my system. I'm purchasing my Kenwood XXV-05V as soon as my Jensen VM-9410 sells and then after I sell my sub/amp combo I have I'll be purchasing my Seas Lotus Refernce Comps and whatever amp I decide on.
So far the top runners are:
DLS A7
PPI DCX800.5
Zapco Reference 650.6(Running Front/Rear Channels to fronts)
Out of those 3 which would ya'll pick
Out of those I think it comes down to dollars per watt and what you want to spend. Also which is going to give you the best warranty. I think either of them would work well for you.
See if you can find a soundstream van gogh vga800.5 anywhere.
It's the best amp i've ever owned, i had to get rid of mine because i needed more power for my front stage, and thought it would be silly to keep a 5-channel just to power my amp....
It was 50x4+200x1@4ohms (rms) and 100x4+400x1@2ohm(rms)
The sound was amazing, and power consumption must have been great, considering it was in my volkswagen tdi i had, which only had an 80amp alty.
Phoenix gold
TI 900.7
CENTER, FRONT and REAR CHANNELS
Into 4 ohms @ 12.5 Vdc (IASCA/USAC) . . . . . . . . . .18 x 5
Into 4 ohms @ 14.4 Vdc . . . . . . . . . . . . . . . . . . . . . .50 x 5
Into 2 ohms @ 14.4 Vdc . . . . . . . . . . . . . . . . . . . . .100 x 5
Into 4 ohms Bridged @ 14.4 Vdc (Front/Rear Only)..200 x 2
SUB CHANNELS
Into 4 ohms @ 12.5 Vdc (IASCA/USAC) . . . . . . . . . .25 x 2
Into 4 ohms @ 14.4 Vdc . . . . . . . . . . . . . . . . . . . . . .50 x 2
Into 2 ohms @ 14.4 Vdc . . . . . . . . . . . . . . . . . . . . .125 x 2
Into 4 ohms Bridged @ 14.4 Vdc . . . . . . . . . . . . . .250 x 1
Into 2 ohms Bridged @ 14.4 Vdc . . . . . . . . . . . . . .400 x 1
Common Specifications
Frequency Response . . . . . . . . . . . .±1dB, 20Hz to 20kHz
Signal to Noise Ratio (A-weighted) . . . . . . . . . . . . .>110dB
Input Sensitivity . . . . . . . . . . . . . . . .200 millivolts to 6 volts
DC Input Voltage Range . . . . . . . . . . .10 volts to 15.5 volts
Recommended Fuse Size . . . . . . . . . . . . . . . . . . .80 Amps
Typical Current Draw at Idle . . . . . . . . . . . . . . . . . .3 amps
Minimum Load . . . . . . . . . .1 ohm stereo / 2 ohms bridged
Dimensions . . . . . . . . . . . . . . . . . .25.5L x 10.0W x 2.35H
Front and Center High Pass Range . . . . . . . .40Hz to 4kHz
Rear High and Band Pass Range . . . . . . . . .40Hz to 4kHz
Sub Low Pass Range . . . . . . . . . . . . . . . . .40Hz to 400Hz
Crossover Slopes . . . . . . . . . . . . . . . . . . .24dB per Octave
Twin-T Bass Level . . . . . . . . . . . . . . . . . . . .0dB to +18dB
Fate710
Fate710
Indianapolis, IN
faulkton
