Best 5-Channel Amp(SQ)?
Fate710
I'm need a very "clean" amp that produces close to the exact wattage its rated if not a lil more. Gona be used in an SQ setup.
Will be powering:
1 Comp Set
1 15" IDQ
I'm wanting to run 1 amp on this setup cause of limited space(Ext cab truck). I've been reading I can run the one channels bridged @ 2 ohm and then run the sub chan @ 2 ohm which is what I need. Let me know your opinions.
Well I found a few that put out decent sub power(300 watt range which is what I need).
I've looked at Kicker and PPI so far. Will look into rest now though.
Directed has one too with pretty good specks. I don't think you could go wrong with any of the ones mentioned so far. There are a couple of versions of the Memphis. The newer one has a much stronger sub channel if I am not mistaken.
Unless he gets a PPI Pro 650 he doesn't need a PC amp. Not enough on the sub channels for that sub. The standard PC 650 will only give him 200 watts on the sub. The Pro PC 650 will do 400. The new DCX PPI 5 channel amps are clones of the PRO 650 (AX 606 ART series) amps which provide more power on the sub channel.
yeah that would work. Same as the PRO PC 60 and the others. But the Standard PC 650 is not the same. I just wanted to point that out so he wouldn't end up buying something that wasn't what he thought.
Fate710
Fate710
Indianapolis, IN
faulkton
