Best 12" subwoofers to be powered by Audio Que AQ-1200 for under $300?
CHECK OUT ! c2audio!!! New brand to forums!!!
For 100 dollars :
12" Threatcon-2 Subwoofer
600 Watts RMS
Available in Dual 4 Ohm and Dual 2 Ohm
Dual 2 Ohm: Threatcon-2 12d2
Dual 4 Ohm: Threatcon-2 12d4
3" Copper 4 Layer Voice Coil
Double Stacked 160 oz Magnet
High Current Flat Woven Tinsel Leads
Dual Spider Pack
Dual Stitched Non Pressed Paper Cone-
with Mid Excursion Foam Surround
Enclosure Recommendations:
Sealed: 1.0 - 1.25 ft^3
Ported: 1.5 - 2.0 ft^3 @ 35hz
CHECK OUT : C2 AUDIO || Home
What are your thoughts?
  • Don't want to spend over $300.
  • Need 2 12"s
  • AQ-1200 will be powering them.
  • I listen to nothing but rap.
  • Don't want to be deafened, but want good clean bass. Looking for good sound quality all the way around.
You listen to nothing but rap, yet good sound quality is important. Color me confused as rap has ZERO sound quality to it at all.
x2 on the SDC2.5's matched up with the 1200 amp. I've built a bunch of those set ups.
Wrong. I get you don't like rap, but don't say dumb things.
Santoro300
Santoro300
Tampa, FL
Santoro300
