Belva amp vs. the hifonics brutus
Do you know if there is clipping or if the power produced is "clean"? Looking at the signal to noise ratio it seems like it won't produce a sound as good as the brutus but I'm not sure.
here's some so called "clamp" tests of the belvaone has **** electricals one has okay electricals
most likely clipped, dont trust anything without a scope. would probably back down 200-300 rms off and that should be close to the clean rms. My brx 2400.1D does 2052 clean with kinetic hc 1800 front and back and 180 amp singer alt, if i want more cleaner power/signal out of it, l i'd probably need a good sound processor.
edit: its 2052 at 1.37 ohm after box rise
I don't see the point in one of these amps there gonna cost you around 300$ you can easily get a really nice condition aq2200d or say you spend an extra 75$ you can get something like the apk2500 which is a really nice amp
Someone put the BB5000 on a AD-1, just got about 2k out of it at 12v. It is a better amp then the Hifonics IMO. I would take it over the Auidiopipe 2k's and 2500s but I really dislike AP...just my opinion.
You don't need an LOC. Just use Y adapters and plug the rear HU channels into the amp's sub inputs.
21
  • Locked
241
Amp
275
342
Ahmed Johnson
Ahmed Johnson
E-town in the burbs now.
bgowdy
    May 12, 2024
Brendon Jenness
    May 11, 2024
