Beginner - wiring a sub?
Promethean
7
Oz
Hi, Im looking to connect up a single sub to a basic system (no amp yet). The way a friend of mine explained it, you could just splice some wires off those running to the rear speakers, run them through a high-low converter and straight into the sub, so the sub and the rear speakers run off the same wires. Is this the case, or do you need to run dedicated wires from the head unit to the sub?
Thanks
JD
i would run and hide people are going to FLAME you so bad just //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif you dont run a sub without an amp
Thanks for the heads up. So let me say that if you have some actual advise for me (which may even be dont wire the sub until I can afford the amp), I'd be glad to hear it. If you're just gonna flame, and sit back and feel superior, save us both some time and dont say anything.
Any constructive advice would be much appreciated.
your better off just turning up your your mid bass, because the sub your trying to install will sound similar.
id just hold off and get an amp if i were you. what type of sub are you trying to wire up?
You need more specifics. What headunit and what sub? And yes, you will most likely need an amp, unless you have a stock system with a stock subwoofer you are trying to replace. In any case, those systems come with an amp. So do you really plan on getting an amp? Another thing you could do, if you aren't going to get an amp and the things associated, is get a good headunit and speakers that have adequate mid-low frequency extension. Fully deadened doors will greatly aid with this.
actual advice - do not try to run a sub off a HU that puts out 15-20w full range its just stupid and will most likely fri you internal amp of your HU ...
Is that 15-20 watts rms or max:laugh://content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Hi guys, thanks a lot for all the replies so far. Its a Blaupunkt 'Melbourne' head unit and a 10" MTX Thunder4000 sub (I think). It has come complete from a system that has been running ok for a while (with no amp, to my knowledge), which is why I thought I could get away with wiring the sub in without the amp until I can get one later down the track. But from most of the replies here, it looks like I should probably just leave it disconnected until then. One of the guys locally that I spoke to said that if it has been wired up before, it probably wont blow the HU but just not get enough power and basically just act like a speaker, is that a reasonable call?
underpowering speakers/subs causes damage to the woofer and could also blow the rear output on the deck, most decks hav wiring diagrams in the manual saying that it can be done at a 2ohm load or more..... most power rms that speaker would see is about 40rms witch isn't enough to run your sub without doing it damage.. hope this helps you
haha........... one time a person at my school actually had two jl 10's hooked up to his head unit and i went in his car and listened to it, and i couldn't even feel the bass. If you hook a sub up to an amp you are really wasting your time.
i would seriously not let it be known you even thought about this idea
Promethean
Promethean
Oz
lbjshaq2345
