Beginner question - hope its not too late
tuckj
Allready installed:
1- 500/1 jl amp & 2 12w3 subs (custom box I made myself - looks good)
1) The amp is rated at 500 watts continous
2) The optiumum range for eash sub is 250 watts.
3) Subs are wired in series = 4 ohm load
Everything lite up nice - sounds good.
I was reading your forums and found many postings on "gain setting" and decided to give it a try.................when I reread the instructions, I started asking myself questions I can not answer.
Serous question - is it ok to assume that I can run 2 subs (rated at 250 continous) on an amp that is rated at 500 continous and not harm the subs? This is an assumption I made.
Please tell me what voltage I need to achieve when setting my gain - there are 2 subs in series
Thanks a million
tuckj
that amp is pretty much a perfect match for those subs. 250 wRMS x2 = 500.
check out JL audio's gain setting tutorial. they will tell you the exact voltage you need for your 500/1.
Thanks SSS 18734 - your quick reply is appreciated.
I am familiar with the JL tutorial.....................so if the chart says that the 500/1 @ 4 ohm imp = 44.7 volts. Is 44.7 my target?
Thanks
tuckj
tuckj
tuckj
Canada
JimJ
BP1Fanatic
BP1Fanatic
