i did the b 3 and got good gain in voltage, but dimming is still killing me.
but my voltage is atleast .5 volts higher, just wished it helped with dimming..
you mite have to do the big 4, if youve allready upgraded all three, then upgrade the + wire that goes from you batt to your fuse box, i used 4ga helped in my car.
What is more important on the big 3, upgrading the grounds, or upgrading the alt to battery wire? If you could only do one of the 2, which would it be and why? Just curious as to see the opinions here... or does it not really help to only do only one or two of the three?
The reason I ask is because in my car I'm having a difficult time upgrading the alt to battery, but I've upgraded the bat. neg. to chassis, engine to chassis, and transmission to chassis, since it was also connected to the same factory ground terminal as the bat. neg. to chassis. My voltage seems to be fine, but I'm curious as to how much of a difference it will make if I'm able to upgrade the final wire.
AAHHHHH! no! if your going to do it make sure you do it will all the same gauge and do all three, only doing one part of the big three will put alot of stress on the stock wires that arent upgraded= buring fire pain suffering death!!!! jk, but seriously do all three at once or wait till you can
