been out of the game a long time, new set up, what do you think....
first off, im looking at geting these 2 12"s, i have a soft spot for vega's....
(69.95) CERWIN VEGA VEGA-12.4 (VEGA124)
12" DUAL 4-Ohm 400W VEGA Series SUBWOOFER
the box is ...
30" long 13" high 13" deep. all in all it has 2.105 volume, and made out of 3/4 MDF
looking at running this amp...
(69.95) BOSS PH2.500 (PH2500)
Phantom Series 1000 Watts 2 Channels MOSFET Car Amplifier
going to run the sub's like this... 2 4ohm dvc's at 4 ohm load
i have a 08 dodge caliber and all 4 door's run 6x9's in them, so i was looking at these for that...
(49.95) ROCKFORD FOSGATE R1693
PRIME Series 6x9" 3-Way Full-Range Speakers
with this amp kit
(14.95) THE INSTALL BAY AK8
1000W Amplifier KIT w/ RCA Cable & AGU Fuse Holder
it all comes to $324.70, did not think that was to bad......//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
let me know what i did wrong or right, or how you would change it, but it must be in the same price range...//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
why not that amp? i know its not one of the big name one's, but is there some other reason? not the watt's i need ? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
some amps may say 1000 or 2000 watts max, doesnt mean it will do that. little rule of thumb (for the amps that have the fuses) for every 10 amps of a fuse will be equivalent to 100 watts of power. example. it looks as if that boss holds one 25 amp fuse, so you can expect around 250 watts out of it. some amps dont have the fuse already and will require an external fuse, in which the manual will show what size fuse you would need.
so the Bridge 1 Channel: 300W x 1 @ 4 Ohms bridged (RMS) would work with the 400w's i need to rms the 2 12's ?
absolutely. 2 dual 4 ohm subs like yours can be ran at 4 ohms bridged which will pull full potential out of that amp. i think its a pretty good fit actually, but opinions do vary. im saying it will sound a lot better then that boss though. no offense, just tellin ya.
so the quality of the audiopipe is lots better then the boss. thats fine. like i sead im new to the new stuff, last stuff i ran was in the early 90's, had a RF punch 150 to 2 vegas ! lol... this is for the wife in her car.
so all else is good to go, just need the audiopipe amp......
pretty much so. if you can get 4 gauge instead of 8 for the same price, i would highly suggest that as well. everything else seems to be pretty legit. good luck with the install.
Pug}{maN
Pug}{maN
in a galaxy far far away Adrian MO.
Pug}{maN
