I want to know, i have been told by many things by people that claim to be Car audio gods, but in the end didnt know anything at all..
Im under the impression that if you want bass that punches you need to have a sealed box, im running a 12" sub 500w rms but im only feeding 250 rms; in a ported box. The sub is really loud and has really good rolling bass, but when it comes to punch it doesnt quite hit..
the box was made for 29hz and i made it exactly as the instructions from one of the tools said, its built perfect and sounds good. I just want to know..
If i make a sealed box for this sub, will it increase the punch but still keep most of the loudness / rolling bass..
And if a sealed box is a good way to go, then here are specs of sub, if i mention a name there will be argueing between people and me so the name doesnt matter, just how the sealed box should be made..
Specs:
Program (conservative)
T Yoke: Industrial Chromed Hex bolt retained,
Bumped and Vented
Double damper magnetic motor assembly
Cooling: Double Vented (T Yoke and Motor Side vents)
Voice Coils: 4 Layer Dual 4 Ohm High Temperature black Aluminum
Voice Coil Diameter: 2.2"
Nominal impedance: 4 ohms / per coil
DC resistance (Re): 3.2 ohms each coil
Frequency range: 20 Hz-1.1 kHz
Fs:30 Hz
QTS:.526
QES:.614
QMS:7.698
VAS:56L
SD:.0491M
SPL:90 dB 1W/1m
Xmax:16mm
Thanks ahead of time..
Specs:
Bumped and Vented
Fs:30 Hz
QTS:.526
QES:.614
QMS:7.698
VAS:56L
SD:.0491M
SPL:90 dB 1W/1m
Xmax:16mm
