Bass Shakers
Decado
Hey, i was wondering if this plan would work, if i got 4 of these http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=299-027 and put them under the seats in my car, and hooked them up to the speaker connections on my head unit (i have my 5.25"s and 6x9s hooked up to an external amp). And 2 questions about this if it would work, would i need to get a low frequency crossover for these? And would this not go very well with my subwoofers (would it cause the bass sound from the subs and the bass feel from the shakers to make kind of a muddy sound/feel)?
those things sux. doubt you will be able to hear those things. if all you want to do is shake your seats than they will but if you put 2 under each seat or just get some real good subs and you'll be set.
they look good...bass shakers....never heard of them...maybe i'll try...btw i dont think ur supposed to hear it but feel it
die GCAdidas die
= //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
have you experienced them ? because don't diss if you haven't. they are good. here are some pictures.
off of THIS amp
installed HERE
it seriously made GTA:San Andreas and the movie Snatch's bass lines sound so much lower...
NOTICE
you must install these in a 4"x4" square flat area where they will get full contact to whatever you are mounting it to. otherwise they will do nothing
and you should give them 35-50 watts or they wont do much either
it seriously is movement enough to mess up your vision like a sub at 140dB or so
I did a f-150 like 2 years ago with some aura bass shakers and you dont hear you only feel the vibration, which give the feeling of having a 2 high powered 8" sub IMO\. Felt kinda cool though
Decado
Decado
Minneapolis, MN
GCAdidas13
