Bass Setting For Adjusting Gains...
also, when setting my gains on my amp, wouldn't using a 30 hz tone be better then 50 hz if i listen to heavy bass mostly?
mid @ +4
high @ +6
loud set to high
kicker 2500 set as follows
freq. around 80 hz
gain about half
bass boost @ 0
subs are fi bl 12"s in 4.5@32 hz
Set everything to 0, then go from there. Having your level adjustments all over the place shows your amps probably are not set correctly.
Edit: N/M it looks like your only running a sub amp. I would still adjust the gain with the sub level at 0.
luv2shrOOm
In my TONKA !!!
luv2shrOOm
luv2shrOOm
BP1Fanatic
BP1Fanatic
