Mark97213
Installed: Alpine Head Unit INE-Z928HD, Alpine AMP PDX-V9-5, JL Audio 13TW5-3, Focal 165 KRX2, FOCAL PC 165. 2011 Chevrolet Silverado 2500HD
I've always had pretty good luck troubleshooting or finding someone that can cure any car audio performance problem but now I have problem that even the pro's at Car Toys can't seem to fix and I'm really at a loss of what to do about it. I was hoping I could get some advice from some on the forum for what I should do next.
This system is everything I need and gives more than I need with great bass output that sounds fantastic when everything is working correctly but, it has an intermittent bass problem. During play, the bass will intermittently drop off for a period of time or just completely dissipate to zero output for as long as five minutes and then, mysteriously come back to normal levels. However, this chain of events will just randomly occur and randomly correct itself.
The system was purchased and installed at Car Toys and has been back to Car Toys, twice, to correct the problem that, either they can't replicate or they say it has been "fixed." However, the problem is intermittent and each time it's been back to them for repair, this issue still remains. They've adjusted the amp, checked connections, changed ground points, etc., all to no avail. They've also said they changed out the amp but I'm not sure they actually did. Their concern for "correcting the issue" is met with skepticism that an issue even exists. Over the years, I've had very good experiences with Car Toys and after several installs, I've always been thrilled with their work but now, with this vehicle, I've hit a wall and I'm not sure how to deal with it and am hoping to get some of your advice.
