Bass Lights
khi
¤ Iñdi° Møâñin ¤
Hey guys....
im sure most of you have seen or heard of bass lights....those lights....that light upacording to the bass...
but do any of you guys know how to hook them up?
if so...let a brotha kno //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
thanx
p e a c e
Use the converter, running directly through an amplifier can potentially burn up the lights or the vehicle. Amplifiers are made to power speakers, not lights. Someone who knows electronics well can probably even make you a converter if you are short on cash, as my signiture suggests...
i picked up a pair of neon tubes at walmart for 10 bucks each
they light up according to the vibration from my subs
all ihad to do was cut off the cig adapter and wire them up with a switch and connected them to the fuse box
theyre mounted under the dash so all you see is light and not the actual tube
khi
¤ Iñdi° Møâñin ¤
khi
Calgary, AB
kingpin_jeffie
michigan born
    May 14, 2026
michigan born
    May 14, 2026
