bass boost
I use mine. I boost 25hz 12 db, it gives me some more low end on my sealed box. Think of it a tuning aid. Try out different settings, youll find a sweet spot, even if that spot has the boost off.
usually wanted or needed on comps when u have no sub (yet)
I would avoid running bass boost on components, as they typically aren't designed to produce high levels of output in the subbass region, where most bass boost center frequencies are located.
And with 12db of boost, that means you are asking the amplifier to increase it's power output by 16x at 25hz. Since that's very likely not possible, there is a very high probability you are clipping the heck out of your amp.
That bass boost knob isn't free power.
IF you are going to use actual bass boost, set it prior to setting your gain. And if you are doing the DMM method of gain setting, use the bass boosts center frequency as your test tone when setting the gain.
correct, but if u plan on running your comps full range for a while and only turn up the bass boost until it becomes just noticable, i think you'll be golden. i did that when i had my little profile amp.
My system it sounds great with it set that way. Ive tryed different amps and they all love that setting. I am running a 500/1 to 2 10w1 sealed in a small box behind the seat of my crewcab truck. Sounds nice for what I can fit back there. I have the gain down quite a bit and with the 10w1 only needding 150w per sub I think I have enough headroom. I wish I could port the box. I appreciate the input as you seem very knowledgable.
stishdr
stishdr
oshkosh, WI
chucku
NorthFramingham
    Jun 30, 2026
