Whats the diff? BB just increases signal voltage at a given freq (ie: same as adjusting gain at thatfreq). Actually, I thought some BB remotes actually are nothing more than a gain knob.... no?Actually, I'm pretty sure Steve Meade uses a remote gain which is NOT the same thing as a remote bass boost.
The remote gain knobs I have used just attenuate the gain but do not raise it from the setting you have on the amp. So basically if you set your gain correctly and crank the gain knob to max, you will not exceed the gain setting on the amp. Full tilt on the remote gain will be at 100% gain setting on the amp.Whats the diff? BB just increases signal voltage at a given freq (ie: same as adjusting gain at thatfreq). Actually, I thought some BB remotes actually are nothing more than a gain knob.... no?
So the knob only adjusts the gain down basically? Full tilt on the remote knob is merely what the signal would be without a knob at all?The remote gain knobs I have used just attenuate the gain but do not raise it from the setting you have on the amp. So basically if you set your gain correctly and crank the gain knob to max, you will not exceed the gain setting on the amp. Full tilt on the remote gain will be at 100% gain setting on the amp.
Correct. That is how the remote gain knob has worked for me. I've never used a remote bass boost knob so I can't comment on them.So the knob only adjusts the gain down basically? Full tilt on the remote knob is merely what the signal would be without a knob at all?
So, ideally, you would set your gain on your amp to the highest *****SAFE***** setting with the knob all the way up, then turn the knob down for normal use and turn it up a bit when you want a little extra?The remote gain knobs I have used just attenuate the gain but do not raise it from the setting you have on the amp. So basically if you set your gain correctly and crank the gain knob to max, you will not exceed the gain setting on the amp. Full tilt on the remote gain will be at 100% gain setting on the amp.
How do you figure 1/4 BB means no distortion added?Bass boost doesn't have to be a bad thing, though I suspect alot of people use it unwisely. It can make your sub distort. I use it, but only a little. I have mine set at 1/4. It just gives the bass a little extra boom WITHOUT the distortion. Any higher I could run into problems and possible clipping. Just be careful, thats all!
Bass boost is for P*ssies that can't learn how to actually run there system right so they put up that and think they sound good but other's like me and others other here would know for sure it sound's like sh*t haha.
joo are such a complete and utter ubernoobzor.i guess im a big ***** then.....and im still learning how to run my system right, got any pointers?
